Hello JohnSpooner,
first of all welcome here and Merry Xmas!
I own a racer S 2015/16 too.
@ Kettmaps.
Yes only Smartphone shifting and no heart beat if you don't use a BT heartbeat belt.
The racer S 2015/16 has only a integrated 5 khz HB receiver.
You can check if there is a FW update available for your racer S 2015/16 by starting FirmwareUpdate.exe in your folder C:\Program Files (x86)\KETTLER\WORLD TOURS 2.0
You have to repair BT again for this Programm.
I think your FW is up to date.
For the 2018 Kettler with premium display you have to download the FW software from kettler.net. So it depends of the Kettler devices.
My advice try KWT! Heartbeat and the Kettraces etc. You can export all your KWT trainings to the freeware program Golden Ceetah. So you have a complete training analysis.
You have to install Microsoft net 3.5 first to your PC before your install KWT. Then update KWT before the first start to vers. 2.0.5.12. from here -> software.
Greetings from Austria
[Dieser Beitrag wurde 1 mal bearbeitet, zuletzt am Dec 25, 2017, 7:16 PM.]
